ORIGINAL: goirish
I watched the video and the problem I am having is the wire from the battery is so large. Probably 3x that in the picture. I could tin the deans but the wire was so heavy that I could not get a good tin on it. can I remove some of the wire so I can fit it inside a anderson power pole connector.
Give it a tin job then use a wheel or clippers to remove what you need. Not the best thing you can do but it works. I use the plier end of my wire cutters to sort of shape the wire. Sometimes it is squaredand sometimes flat, whatever works.
