RCU Forums - View Single Post - What would you build for these beasts?
Old 01-02-2011 | 01:21 PM
doxilia's Avatar
doxilia
Default RE: What would you build for these beasts?
Speed Panzer,
I see your point. In that case, I will follow your advice and plan on using a long stroke engine in the Saphir. I do have a pumped YS that could serve well there.
Back to the Webra's in question then, it seems like an upright install for the Speed 61R might be a better option. Good suggestions so far:
[ul][*] Arrow[*] Bootlegger[*] Tiger Tail 4[*] EU-1A (not sure if this design might call for a LS too and perhaps an 80 to 100 2 stroke)[*] Escape (I prefer the Escape to the XLT and have a kit)
[/ul]
It also sounds like the 80 needs to turn a 13x10. Are there any "mystery" designs that could use that displacement and prop to good effect? I've even thought of a custom sized Tipo (but don't want to cut more Tipo cores) or something even as sporty as a large Side Pocket. Neither convinces me though. I may just have to use it in the 90 size CAP 21 project although I was planning on electric for those scale designs - all around simpler in cowled applications. Besides, these engines need to be seen!
David.
