RE: Bellcrank Problems...
if i am understanding right you are talking about the servo saver. something is binding or your settings on your transmitter has to much travel set in it. i would check your settings on the transmitter first try that. my ofna lx 1 did the same and the settings was the problem. the spring might be to weak in the servo saver also.
