RCU Forums - View Single Post - Rx question
Thread: Rx question
Old 01-02-2011 | 03:32 PM
oldtyme
Default RE: Rx question
ORIGINAL: Johnnysplits
ORIGINAL: oldtyme
Yeah......we were talking about this the other day. I just mount foam on the airframe with double sided mounting tape and then mount the receiver on the foam with double sided mounting tape. I have this in several models and it works great with plenty of air being able to get to the receiver.
Does the double sided tape keep the Rx stuck to the foam by itself, or do you use a zip tie on it as well?
Yes the tape itself holds the Rx just fine. The tape I am referring to is servo mounting tape and it sticks really well. I have had to take out an Rx once or twice and it ripped up the foam and was somewhat challenging to get off of the Tx but with a small amount of Goo Gone it came off the Tx just fine. If you are nervous you could also use a zip tie but I don't and have not had a problem.
