RCU Forums - View Single Post - Throttle stick position while flying!!!
Old 01-03-2011 | 04:40 AM
  #36
sandal
Default RE: Throttle stick position while flying!!!
Going from a 15x8 to a 15x4 will, as you noticed, increase rpms significantly. A 15x4 needs less engine power than a 15x8 to turn at the same rpm. To keep rpms the same, you need to increase diameter. A 16x6 will load the engine about the same as a 15x8, but give more thrust (and lower top speed).
