 Throttle stick position while flying!!! >
Old 01-05-2011 | 03:49 PM
  #51
hugger-4641's Avatar
Default RE: Throttle stick position while flying!!!
ORIGINAL: ameyam
Ok, I always wanted to ask this question- what difference does and APC make over a MAS of the same size (other than that the APC breaks more often)?
Ameyam
This can be an advantage or a disadvantage. MAS props do flex more than APC which means maybe they don't break as easy from ground strikes. The fact that the MAS props flex a little allows the pitch to drop slightly under a load. So lets say you are using a MAS 11x6 in a hard climb at full throttle, the prop will flex some and actually give you performance closer to that of an 11x5. Then when you level back out, the prop will flex back to higher pitch.
If that's what you want, that's great. Personally I prefer APC props on most of my planes because they don't flex and pitch remains more constant. Exceptions to that are the two Avistar's that I use for training folks, and my Somethin Extra, which I do some limited 3D with.
Old 01-05-2011 | 07:41 PM
  #52
armody's Avatar
My Feedback: (10)
How about TT props and Xoar props?
Old 01-06-2011 | 03:00 PM
  #53
I personally have not used either of those, but many at my club use the Xoar props on bigger planes with 15" to 20"+ props.
Old 01-08-2011 | 10:01 PM
  #54
armody's Avatar
My Feedback: (10)
Update of my flight today.
I flew my Strega with APC 11X5 prop, I did feel a very little difference at the take off, I felt a little bit more thrust in it but haven't tried 11X4 on it. I ran my motor rich and during the flight, I felt it did little bit bog down, as I went to flying field after 3PM as I had always been morning flier but somehow I've started going late. Anyway, I could not probe into my motor's bogging while flying only one time, but I felt the plane flew well, and speed wise it was as same as on 11X7.
I did get to fly it on half throttle due to wind somehow my plane does flutter and did flutter while in the air, but little less than half throttle, I was flying little low and I did feel that this time I need to push throttle gimbal little forward otherwise my plane was coming down to the ground, but that's again the throttle setting. I still feel that I need a little more tweaking to my motor, and I think I have opened my needle lil bit more than 3 turns, I got the sound of the engine, which I wanted it to run, it runs smooth and I enjoyed half throttle during my 3 flights. I'm gonna make some changes on my high speed needle and update you guys. I think my engine got much more rich. As a gallon of 10% Nitro fuel is $21+, one of a very experienced flier who flies big gassers and sometimes electric that 10 to 20 years ago, he used to use 30% Nitro fuel, he said motor runs good and keeps it cool. As I also read that for motors like .46 to .91 2 Stroke. 10% Nitro fuel is good how about going to 15% from 10%, but I gotta say that the prices of the Nitro fuel is really deriding.[:@]
Thanks again y'all for your great inputs and I'm gonna update y'all next week again
Happy Flying
Mody
Old 01-08-2011 | 11:28 PM
  #55
jeffie8696's Avatar
I like the looks of that Strega buddy.
Old 01-08-2011 | 11:44 PM
  #56
armody's Avatar
My Feedback: (10)
It's no doubt a good plane, It flies good, but as it's smaller than Mustang, either I feel it or somewhat due to winds, it flutters sometimes, again I think it's wind.
Old 01-08-2011 | 11:49 PM
  #57
armody's Avatar
My Feedback: (10)
Jeffie,
I absolutely loved my new Mustang crashed[&o] I loved Strega, 2 flights crashed[&o] but this Strega flies good and I'm flying it more safely and carefully.
Here are some pix.
ID:	1544526   Click image for larger version
ID:	1544527   Click image for larger version
ID:	1544528   Click image for larger version
ID:	1544529   Click image for larger version
ID:	1544530   Click image for larger version
ID:	1544531   Click image for larger version
Old 01-09-2011 | 05:56 PM
  #58
armody's Avatar
My Feedback: (10)
Correction, I loved Escapade, it crashed too. Currently flying Strega.
Sorry about the confusion.
Old 01-09-2011 | 06:50 PM
  #59
scooterinvegas's Avatar
When you need that little extra to push you over the cliff....... turn it to 11
Old 01-11-2011 | 08:36 PM
  #60
armody's Avatar
My Feedback: (10)
Turn it to 11 News lol ?? or Turn the stick to 11?
Old 01-11-2011 | 09:11 PM
  #61
Sorry armody, Im showing my age with a obscure Spinal Tap reference. LOL
[youtube]http://www.youtube.com/watch?v=EbVKWCpNFhY[/youtube]
Old 01-11-2011 | 10:48 PM
  #62
armody's Avatar
My Feedback: (10)
Lol, that's good. I love playing guitar as well, just basic guitar I have, can play power chords and some basic chords.
It cannot be 10 it has to be 11 so, this is how I have to use my throttle gimbal at 11 lol.
Old 01-12-2011 | 10:40 AM
  #63
It would really help you to invest in a tach. With some experience you can get close by ear, but a tach is the way to get the most out of your engine without hurting it. Use the tach to find your max RPM, then richen up till you lose 300 to 400rpm. You'll be amazed how much better throttle response you get when you are tuned properly. This is the tach I use.
www3.towerhobbies.com/cgi-bin/WTI0095P
Old 01-13-2011 | 08:48 PM
  #64
armody's Avatar
My Feedback: (10)
Thanks hugger,
I've been thinking about to buy a Tach for a long time, but every time I wanna buy it something else comes along. It's in my list to buy one
Thanks for the suggestion and you are right, with the right rpm, I can better setup my motor. Lately temperature has gone down a lot in TX and it's also making motors gone cranky on top of that this weekend we have 40% and 60% more of less chances of showers and thunder. Let's see if I can squeeze few hours of flying before it showers.
