RE: Habu 32 with P-20 Conversion first flights :)
Thanks Darren.
As soon as I decided to make the conversion, it made sense not to have plastic Dubro just slapped in there. Marc has made a few custom tanks in his time, and did a great job. The built in hopper tank is what really tidies it up.
I wanted to use a big RX, just to prove that there was enough space with this set up.
I bet you are looking forward to your P-20 now? I know the Bu is only the second P-20 jet that I have flown, but I can fully recommend it. The only improvement that I can see making on it ( Apart from colours ) would be the fitment of trailing links... not sure how easy thats going to be on the mains, but might just start on the nose first of all, although from asphalt the wire legs were perfect.
Regards Al
