RCU Forums - View Single Post - FS NUMBERS
Thread: FS NUMBERS
Old 01-03-2011 | 12:40 PM
RalleKnalle's Avatar
RalleKnalle
Default RE: FS NUMBERS
Hi,
I have the FS fan decks in stock, have also the 3X4 color chips. I´m using that color chips to mix the paints, the matt painted chips do work too. You have to make them wet (with spit). Have made the recipes for most FS colors. (using automotive Valspar base coat tints). If you are using a scanner, will work too. you have to make the flat surface wet. But the scanner is using a color library and will be not able to find recipes matching close to the color chips. sometimes you have to mix with help of your eyes...Blue, red, green and yellow work fine, but grey (and other camo scheme colors) will be a problem....
if you need help to find right matching FS colors, please let me know.
