RCU Forums - View Single Post - Littlest Stick Help
Old 08-05-2003 | 11:36 AM
Lynn S
Default 150% LS
Originally posted by flyinrog
sounded like all good advice Bruce,, hey Lynn, I'm gonna try that 150% thing on the copier at work tonight..it was a pretty simple build , so it should be just as easy , and I need something to put behind my BW,and maybe later put the teedee on....thanks, Rog
Build everything with 3/32" sheet balsa, and use 1/4 x1/4 for the spars. Just use 1" dihedral at the wingtips. This is just like the Simple Extra uses except the Extra has a foam wing with no spars. It turns out to be the same size as the Extra. You will like it! - Lynn
