RE: Comp ARF Valiant
flyncajun
Or anyone else that did the chin per-manual....
How exactly does it work?
Do you FOrce the two pins (bolts) throught the wire?? Which moves the wire out of the way to allow the rounded bolts out/in ??
Or do you make a slot on the outside of the fuse so it slides??
Do you then pull the wire on both sides and then pull the chin out???
Could you show some pictures of a finished example..???
It would be very helpfull and most appreciated...
Justin..
