RE: Custom charge case
I have used that power strip before and it is really under sized for a charger pulling 20+ amps. If you are using it primarily for charging receiver packs etc, it's fine but look inside and the wiring and connections are pretty small gauge. I changed all the wiring in mine to larger gauge wires and it worked fine but still got a little hot at times.
