RCU Forums - View Single Post - I need a soldering lesson
Old 01-05-2011 | 11:33 AM
  #31
StevL
Default RE: I need a soldering lesson
ORIGINAL: RealFly
First and foremost. You must match the solder to the item. For ELECTRICAL connections you should select solder with a rosin core flux. It is commonly found at radio shack. Most of the time if you use proper solder and a clean iron you will not have a problem with electrical.
Well said and spot on!
Steve
