RE: help removing engine
obviously i have the prop spinner and cowl off if i can see the mount bolts,
thanks 52larry52, thats what i was looking for i didnt know if i had to remove the needle valve. i see that the high speed needled valve shares 2 bolts with the backplate to the crack case. it will be okay if i remove these 2 screws without messing things up in the crankcase?
