RCU Forums - View Single Post - need more info on counter steer
Old 01-12-2011 | 03:59 AM
LILJAY2
Default RE: need more info on counter steer
Ihave been drifting countersteer for a while now here in Japan, two main things for countersteer is parallel steering and like you said rear tires turn faster. Even though your car is shaft driven you can installed countersteer gears, look at you rear diff case and look at your gearing, Yokomo sells countersteer sets 1.5 and 2.0 I have it installed ina Yokomo MRTC-4 LCGcahssis, by the say trying to sell it for $350 dollars with motor installed, drop in your radio and battery and you are off
