RE: Help with 3 view
Antonio, I fixed the link in your first post. You had a "," at the end of the address as sentance punctuation. If you post a link at the end of a sentance you MUST use a space after it to separate the comma or period from the link. I also replaced a bunch of your commas with periods and capitals to separate the thoughts into proper sentances. Hope you don't mind. It makes your post easier to read.
Examples- Note that I included a space in the "w ww" part to make the links non functional just for this example.
Go to w ww.link.com. - this won't work as the period for the end of the sentance gets stuck to the link address
Go to w ww.link.com . - This will work because the link is separated from the period by a space.
Molo 30, if your drawings do not have any cross sections then there is no way to accurately produce them. Oh sure, you can guess and they'll likely be close enough. Especialy if you use a lot of pictures of the real ones that have lots of shadow line details on them so you can get a good feel for the shapes and how they transition from one area of the plane to another. But such guessing at the right shape won't cut it for world class scale competition. It would be good enough for sunday scale flying though.
Another thought is that smaller 3 views that do not have multiple cross sections are often not all that accurate for the stuff that they do show. It helps to find multiple drawings and compare them. So consider the source of your drawing before you trust it.
