RE: SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION
On a Walbro, if there is a hole that exposes the butterfly shaft on the gasket face of the carb, it is has a accellerator pump. The pump is a spring loaded piston that moves on a flat spot on the shaft. It looks like the Zama might be the same from your picture.
