RCU Forums - View Single Post - Smoke spryer at end of Pipe???
Old 01-16-2011 | 03:29 AM
Xairflyer's Avatar
Xairflyer
Default RE: Smoke spryer at end of Pipe???
Depends on the distance and pre heating helps alot, need to get a fine mist to work best.
There is still a fairly high temp at the end of the pipe not much different from a Gas engine so will also probably work better with the smoke oils rather than just diesel/kero.
