RE: AFDP display problem with Radeon 5770
This could be some videocard driver compatibility issue with your system and I rarely see it. However, you can use the mcf file to force the window size and it's not really a problem anymore. I am running AFPD and AF5 about the same system config as yours without a similar "problem". On the AF5 running in your system, you could also use the mcf file if you face a similar issue.
