RCU Forums - View Single Post - Smoke spryer at end of Pipe???
Old 01-16-2011 | 09:16 AM
Xairflyer's Avatar
Xairflyer
Default RE: Smoke spryer at end of Pipe???
ORIGINAL: Jetpilot24
ORIGINAL: Flynstuff
<div style=''margin: 0in 0in 10pt''>Guys.
Has anyone done a smoke system with the smoke spryer at the end on the pipe instead of the turbine tail cone?</div><div style=''margin: 0in 0in 10pt''> </div><div style=''margin: 0in 0in 10pt''>Is there enough heat??</div><div style=''margin: 0in 0in 10pt''> </div><div style=''margin: 0in 0in 10pt''>Thanks for your input.</div>
Flynstuff
I run a 3/16 brass tube between the dual walls of the tail pipe then bend it at the end of the pipe. I stick a #11 Exacto blade in the of the brass tube then squeeze it and take the blade out. This set up works great. I have may Smoke pump travel in my radio set down to 35% and I get a nice thick smoke trail.
Joe Lewis
Kingtech
K-80 owner
What length is your tail pipe
