ORIGINAL: kochj
Thanks wayne..
Looks like they supply the regular sizes....
I am looking for the 1/4-32 size set to go...
I found this site....
Agape Racing and Hobby has one already to go....
No need to buy additional parts and hastle...
1/4-32 90 Deg RCEXL Ignition System-Single Cyl.
1/4-32 Mini Spark Plug-Single Cylinder-90 Degree
55$ + shipping...
You must have called them? All I saw on their site was a bunch of cute dogs and some RC engines.
CAll them back and ask them if they do the soldering of the stainless steel 1/4-32 metal shroud themselves. And if it's the RCEXL kit. And most importantly, ask them if they're willing to put reinforcement strips soldered onto the 45% angles on the metal shrouds (2x 45 =90 degrees overall). If not, there's a danger of the solder joint breaking during flight. That has happened to me twice. When CH Ignition was in business, they used to reinforce mine for a nominal fee, by soldering a double across the solder joint. And that turned out to be worth a fortune in reliability.
If you're not sure what I'm talking about, I can supply a photo, or a drawing.
