RCU Forums - View Single Post - Wild Hare Electrics
Old 01-18-2011 | 10:38 AM
  #170
matt_xb8r
My Feedback: (8)
Default RE: Wild Hare Electrics
Jon,
HAHA...all the info I can get helps....it doesn't irritate me in the slightest to continue the discussion.
But here's something to think about that is a more along the lines of what I'm looking at.....with regard to your example above lets say you have a 3s setup and a 4s setup. Same motor, esc, and prop. Spin them at the same RPM or spin them both up till the wattage is the same. At that point what is the current draw on each? Icompletely agree that if you run them up to max throttle there is an increase in everything when the 4s is compared to the 3s.....but what happens when you choke the 4s down to meet the performance limits of the 3s? Its at that point that you should see where there is a decrease in current pull when they are compared side by side.
Matt
