WildHare R/C Support Disscuss WildHare RC products in this forum. Please note, answers may be provided by Tom Fawcett (owner of WildHare RC) or by the general membership.
Wild Hare Electrics
Old 04-10-2011 | 06:38 AM
  #201
rctom's Avatar
Default RE: Wild Hare Electrics
My advice for IMAC type flight was to set it up so that the throws you plan to use are achieved at full servo travel. IF you only need 12 degrees of elevator travel, set it up so that full throw on the servo at high rates gives you 12 degrees. Anything else is wasted.
This gives you maximum servo resolution.
TF
Old 04-10-2011 | 07:12 AM
  #202
My Feedback: (50)
I have been flying my Edge I have a problem when I fly inverted it wants to roll to the right a little but it flys straight and level right side up Knife edge it wants to pull to the belly hard any ideas how to fix this problem
Old 04-13-2011 | 10:28 AM
  #203
I don't whom you were asking for sure but in my case, since I only want to fly IMAC "style" manuevers I only have one rate. The dual rate switches on my transmitter for this type plane do nothing. I only use them if I want to test out a higher or lower rate. I set them up temporarily to test out the new rates and once I decide which one to use I set high/med/low rates to be all the same. I do have another airplane or two where I have multiple rates or conditions but for my IMAC style aerobatic planes... one rate... "just enough".
Old 04-18-2011 | 07:18 PM
  #204
Hey Tom,You have a 56in Edge/slick and power set for 200.00 still,let me know thanks
Old 04-19-2011 | 05:42 AM
  #205
rctom's Avatar
ORIGINAL: skip1320
Sorry, all gone.
Old 04-19-2011 | 06:12 AM
  #206
No airframes,any on the boat or in future,thanks,Mine is great!
Old 04-19-2011 | 06:13 AM
  #207
Are you planning on selling any more of the 56 e-edges/slicks?
Old 04-19-2011 | 08:40 AM
  #208
rctom's Avatar
I still have a few with a bow on the leading edge of the ailerons, would be easy to fix or just ignore, but that's all I have.
I know it was a nice plane but due to problems with the builder (like bowed ailerons) I won't be buying any more of them.
TF
Old 04-19-2011 | 08:51 AM
  #209
Any more electrics on the way?
Old 04-19-2011 | 09:47 AM
  #210
rctom's Avatar
ORIGINAL: JonPa
No, there will be no more. What I have is all there will ever be.
TF
Old 04-23-2011 | 04:13 PM
  #211
by chance anyone have a replacment motor recomendation my motor craped out on me i would like to buy one from hobby king or something cheap. thanks for your help
Old 04-25-2011 | 12:01 PM
  #212
My Feedback: (25)
JonPa...check your PMs
Jon
Old 05-03-2011 | 06:38 AM
  #213
I have flown my edge now about 5 or 6 times and everything has worked well so far. Incredible power! Anyway, on my most recent flight, on the landing I was pulsing the motor to land the plane, and right at the end I heard this loud screeching sound when I pulsed the motor. So it happened at lower throttle and it was accompanied by a loss of power (or it seems the prop was not responding with the noise). People at the field thought it was a slipping collet, but it seemed tight and I could not reproduce it at home in the shop. I decided to increase the esc timing, but am not sure if that is the problem.
Anybody else have this issue or know what causes it?
Old 06-07-2011 | 09:21 AM
  #214
hey guys.
I have a question
I bought the 56inch slick and the 540 edge.
I run a four cell power package with hacker pro motor and esc.
the power setup seems fine but i have a problem with the flight characteristics of the slick. I take off and all is good, nice and smooth go to bank her around and she wants to tuck a wing under. full opposite ailerone to correct. Seemed weird so i got some altitude and banked it again this time with more speed. It turned nice and smooth but as i dont fly constantly full throttle i slowed her down to a moderate landing speed banked her over and once again she tucked a wing and scared the pants off me because i was putting in stick inputs but not much was happening. I resigned my plane to the lawn dart gods but as she spun in i started to get control back and managed to save her. Had to land her twice as fast as i should because i was mortified she would tip on the approach.
servoes are within spec for tourque
centre of balance is 1/2 infront of spar seems good
I dont know about these control throws as i fly a lot of 3d and the more throw you can get the better and its never caused these types of stalls ever. In fact my extreme flight edge 540t has a smidge under 90 degrees on the elevater and it harriers awesome. And i usually setup for full throw and if i need less elevator i put less elevator input into the sticks.
Please help ive had two of these for a long time and im to scared to fly them.
Old 06-07-2011 | 10:37 AM
  #215
rctom's Avatar
Are your control throws set up as specified in the manual? Or did you just put in as much as you can get.
TF
Old 06-07-2011 | 11:21 AM
  #216
i put as much as i could get. As i us a heli version dx7 unless i slave all the control surfaces to one switch its hard to adjust rates without hitting three switches. I guess i go for full rates and use expo to get rid of twitchiness. Never had a problem before but i cant see why this would be a problem. Sure you can over correct or have two much expo causing soggy control feeling but after a few flights you can tune this out .
Would not putting the elevator struts in cause this problem. Thanks for the quick reply
Old 06-07-2011 | 03:21 PM
  #217
rctom's Avatar
possibly, but more likely too much control throw is the culprit.
Old 06-07-2011 | 05:05 PM
  #218
i will give this a try thanks for youre help i will contact with results. Nuthin like readin the manual eh lol
