RCU Forums - View Single Post - Electronic Ignition Module
Old 01-18-2011 | 12:48 PM
pe reivers
Default RE: Electronic Ignition Module
Inside the cowl area where the air can be very hot? If cooling airflow is OK then that will work. otherwise, the hot air will case a severe shortening of the ignition's life span. Today it works well, tomorrow it won't.
