Electronic Ignition Module
Old 01-18-2011 | 09:22 AM
My Feedback: (40)
Default Electronic Ignition Module
What are the guidelines for installing an electronic ignition module?
Where is best site for installation, better inside of fuse or is it
ok out on, say, the engine box. Is it ok to be in close proximity to
battery? How far from reciver? (2.4 GHz if that matters)
Thanks, Robert
Old 01-18-2011 | 11:17 AM
w8ye's Avatar
My Feedback: (16)
Default RE: Electronic Ignition Module
soft mount
rule of thumb 12" from receiver
Battery position is more important for weight and balance
Old 01-18-2011 | 11:22 AM
My Feedback: (40)
Yes, I am going to soft mount but I guess my real
question is WHERE? Thanks
Old 01-18-2011 | 11:36 AM
jedijody's Avatar
Where ever it fits but somewhere close to the spark plug is best.
Seriously, it's not that critical, put some foam under it and zip tie it to the side of the engine box, or inside the fuse, it doesn't matter. Just don't tie ignition wires together with wires leading to the Rx. Keep a few inches separation between the module and sevos, 8"-10" from Rx. </p>
Old 01-18-2011 | 11:44 AM
w8ye's Avatar
My Feedback: (16)
Depends on the design of your plane.
The ones with the box behind the engine usually have the ignition mounted on the side of the box in the cowl area.
Planes like a giant stick will have the ignition module mounted in the front of the tank compartment
Old 01-18-2011 | 12:48 PM
Inside the cowl area where the air can be very hot? If cooling airflow is OK then that will work. otherwise, the hot air will case a severe shortening of the ignition's life span. Today it works well, tomorrow it won't.
Old 01-18-2011 | 01:14 PM
My Feedback: (40)
Not trying to drag this out but: I think I will mount it inside the engine box BUT
I may have to have batteries far forward for balance. Any problem with the module
being very close to batteries, flight pack battery in particular. I want to thank
everone for the help. I am an old guy with a lot of gas engines but they are, up until
lately, of the mag type and I am not familiar with the ignition modules. Heck, some
of my engines have POINTS! Thanks again.
Old 01-18-2011 | 01:31 PM
jedijody's Avatar
You can mount the igniiton module and all batteries right next to each other without any problem.
Old 01-18-2011 | 02:07 PM
My Feedback: (40)
Thanks Jody! I just installed one of those Miracle dual switches with fuel dot from
Valley View in the plane. Looks GREAT. You Folks are a GREAT outfit! ....Robert
