RCU Forums - View Single Post - Servo AMP draw while in motion
Old 01-19-2011 | 07:49 AM
Bax
Default RE: Servo AMP draw while in motion
There's no way to tell, because there isn't a "standard" servo. Most servos will draw up to 3 Amps when stalled. Most are quite a bit lower. "Under load" can mean many things, because the load is always changing. You need to use an on-board recording meter to see what your current load is when you fly your model. Then, you can determine the average current pulled by your system.
