Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Servo AMP draw while in motion
Old 01-16-2011 | 03:57 PM
weskel's Avatar
Default Servo AMP draw while in motion
Wondering what the AMP draw is on a standard ball bearing servo while in motion under a load running with a 6 volt receiver battery.
Old 01-19-2011 | 07:49 AM
Bax
Default RE: Servo AMP draw while in motion
There's no way to tell, because there isn't a "standard" servo. Most servos will draw up to 3 Amps when stalled. Most are quite a bit lower. "Under load" can mean many things, because the load is always changing. You need to use an on-board recording meter to see what your current load is when you fly your model. Then, you can determine the average current pulled by your system.
