<![if gte mso 9]><xml><w:WordDocument><w:View>Normal</w:View><w:Zoom>0</w:Zoom><w:PunctuationKerning /><w:ValidateAgainstSchemas /><w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid><w:IgnoreMixedContent>false</w:IgnoreMixedContent><w:AlwaysShowPlaceholderText> false</w:AlwaysShowPlaceholderText><w:Compatibility><w:Br eakWrappedTables /><w:SnapToGridInCell /><w:WrapTextWithPunct /><w:UseAsianBreakRules /><w
ontGrowAutofit /><w:UseFELayout /></w:Compatibility><w:BrowserLevel>MicrosoftInternetE xplorer4</w:BrowserLevel></w:WordDocument></xml><![endif]><![if gte mso 9]><xml><w:LatentStyles DefLockedState="false" LatentStyleCount="156"></w:LatentStyles></xml><![endif]><![if gte mso 10]><style> Style Definitions */table.MsoNormalTable{mso-style-name:"Table Normal";mso-tstyle-rowband-size:0;mso-tstyle-colband-size:0;mso-style-noshow:yes;mso-style-parent:"";mso-padding-alt:0in 5.4pt 0in 5.4pt;mso-para-margin:0in;mso-para-margin-bottom:.0001pt;mso-pagination:widow-orphan;font-size:10.0pt;font-family:"Times New Roman";mso-fareast-font-family:"Times New Roman";mso-ansi-language:#0400;mso-fareast-language:#0400;mso-bidi-language:#0400;}</style><![endif]><p class="MsoNormal">I got a RTF mSR as a gift from my daughter. This is my first RC heli and I have been having a blast learning how to fly it. I have replaced the the skids with the MIA Tuff Skids after breaking 2 of the stock ones and also the blade grips with a metal one. I have progressed to flying banked turns around the post in my basement and can control the heli pretty well when I don't get too confident. I still crash into the walls quite often, mostly when I run out of room when trying to recover from higher speed moves. I have the dual rate set to "high".
I have a few questions to experienced mSR owners:
1.- I have to give the heli significantly more left rudder to start turning than right rudder (probably around 30% stick travel left before anything start happening). Makes it much harder to fly counterclockwise turns. Is this normal?
2.- The tail will hold direction OK, but it has a bit of a "shutter". Is this normal?
3.- When hovering without any stick input, it will wander in all 4 directions. Is this normal?</p><p class="MsoNormal">4.- Would using a better TX (i.e. DX6i) make a difference in flight control?</p><p class="MsoNormal">Just trying to figure out if I broke something or if all is as it should be since I have no comparison or experience with another heli.</p><p class="MsoNormal"></p><p class="MsoNormal">All input appreciated.</p>
