RE: HobbyKing OrangeRx Futaba FASST Compatible 8Ch 2.4Ghz Receiver
Sorry to hear about your flyaway. At least with a crash you can salvage some stuff. Flyaways are the worst because everything but the transmitter is gone.
I've been flying four of the OrangeRx 8ch FASST receivers for a few months. All four have been working perfectly with a 12FG in Multi mode.
So I'm curious to know a few things about your flyaway.
1. Were you using all analog servos? All digital servos? Or a mix of analog and digital servos?
2. If you were using any analog servos at all, was the OrangeRx receiver set for normal speed mode? Or high speed mode?
3. Did you setup the fail safe on the receiver?
4. Did you disable the fail safe settings for all of the channels in the 12FG?
5. Did the receiver get powered up from a BEC? Or from a separate battery?
