RE: GP Patty Wagstaff - Building & Flying
I've got a question about balancing this plane I am using a BME 50 with the fuel tank and smoke tank on the cg and pull pull rudder instead of the servos in the back. My battery is behind the servo tray. My plane balanced perfectly with a 1800 mah nicd ignition battery in the motor box behind the firewall. the manual doesn't say whether to balance it upright or inverted, I balanced it upright. I've seen some posts on here from guys with a bme 50 that had to have all the servos and battery in the back of the plane to balance. I'm wondering if I am balancing the plane wrong because I expected it to be nose heavy.
