RCU Forums - View Single Post - Funtana ordered. What else is required?
Old 01-20-2011 | 09:48 AM
opjose's Avatar
opjose
Default RE: Funtana ordered. What else is required?
ORIGINAL: ameyam
Hey, I always have the option to try to setup without the syncronsier first. Then if I dont like it, I can look for the syncroniser. I have a 6008hs remember? Its a premium high speed RX
http://www3.towerhobbies.com/cgi-bin...&I=LXWVF5&P=ML
Also, is the servo sufficient?
http://www3.towerhobbies.com/cgi-bin...&I=LXDTB3&P=ML
Ameyam
The 9 channel Futaba you have does a pretty good job with mixes. Yes you can try the setup as you intend first. I recommend performing the little test I mention above to check how the surfaces will do in flight.
For sports planes I often rely upon the TX for mixes, but for my larger 3D planes I use the syncronizers for better accuracy.
And yes that servo is fine for all of the surfaces, particularly at 6v.
Because of the faster servo response at the higher voltage, I use a 6v supply on my Funtana.
