RCU Forums - View Single Post - ASM C-130 101
Old 01-20-2011 | 09:33 PM
  #76
rockinmarine
Default RE: ASM C-130 101
Ok, thats easy enough to check. I will tell you this. Without using a scale and all 4 engines running. It wanted to pull me through the garage. So if I wanted to do easy math. 190lbs divided by 4 engines would be roughly 48lbs of thrust. But I will definately check with a scale.
