24.7 tuning
Ok set your Hs at stock settings, this has nothing to do with the lowend so do not use the HS to fix the doggy lowend. You should get the engine to start in one pull or 2 if the lowspeed is set right!! Now on the other hand you might have some other problems with the engine, so check and see if theres any fluid leaking around the engine!! I probably cant be much help on the turns in or out on the needles becasue I dont use those as a reference, I know exactly how it should sound and run so this is how I tune my engines.
WIth the things your telling me I think you have an air leak some where, obviously something is not right if you flipped the truck and it runs crappy now!!
These are the cause's of your problems, and it could be any of them!
-to rich or to lean LS settings
-air leak in the carb
-air leak around the back plate
-or cracked crank case
Anyways try to lean out the ls needle a bit more, 1/2 turn or so, if this does not help you probably have a pretty good air leak.
