RCU Forums - View Single Post - Pull-pull setup... Ackerman (pics of my setup)
Old 01-21-2011 | 10:52 AM
KitBuilder's Avatar
KitBuilder
Default RE: Pull-pull setup... Ackerman (pics of my setup)
One more question since I'm going to be using pull in earnest on my next build....
I heard it better to get Ackerman by having the control pivot point behind the surface point thereby allowing the lines to be parallel as opposed to a slightly less diameter servo arm leading to a trapezoidal type setup..   Not sure if this is the case but parllell lines are better or it doesnt really matter?
