RE: jittering servos?????
As Lnew stated, it's more likely to be corroded leads. You should get a can of electrical terminal cleaner and make sure you clean everything, switch and RX also. Spray first then plug the leads in and out about 10 times to remove the crud. Some servos also jitter when they have a freshly charged battery installed but the 3004s don't usually react to the battery over charge or fresh charge.
