Hi Mark,
I don't have any of the TP820CD chargers yet to play (should be another 7-10 days) with but here is the data sheet released by Thunder Power. Basically, it is has 2 output channels each capable up to 400watts (at 26V input) and 1S-8S packs. You can combine both output channels together and charge up to a 16S pack so a hard wired 10S pack can be charged with the TP charger. Discharge is limited to 10 amps so that is 1/4 of the rate of the Power Lab. It looks like a nice improvement over the older 1010 charger with higher output and 2 output ports and balance charging. The balance adapters accept both Thunder Power connectors and JST-XH which are the Zippy/Rhino/Hobby King type. Another good option for sure.
TP data sheet:
The all-new TP820CD is the first ever dual port and the most anticipated, most powerful and most advanced multichemistry
charger, discharger, cycler and balancer system from Thunder Power RC yet! With up to 800 watts of total
charging power, nearly 4-times that of the ever-popular TP1010C, the TP820CD is equipped with two ports that function
completely independently to charge, discharge and cycle a wide variety of 1-8S LiPo, LiIon and LiFe (A123) batteries, as well
as 1-24 cell NiCd and NiMH along with 6-30V Pb (lead-acid) batteries. The built-in 2-8S LiPo/LiIon/LiFe (A123) cell balancers,
one for each port, and included balance connector adapter boards are readily compatible with all Thunder Power balance
connectors and the JST-XH balance connectors found on many other batteries.
The dual port TP820CD offers the convenience and flexibility of two separate chargers in a single yet incredibly compact
case as a result of its advanced power conversion technology and all-new Thunder Power RC exclusive design. Each port is
capable of charging at rates up to 20 amps, even simultaneously depending on input power and charge settings, offering
the ability to charge many of the latest-generation LiPo batteries at ultra-fast rates up to 6C and beyond. This means the
TP820CD is well-equipped to quickly charge batteries up to 8S on each port, as well as ‘split’ batteries equipped with
interconnect leads up to 16S by using both ports simultaneously.
Popular examples of the incredible charging capabilities of the TP820CD are the ability to charge two 5S 5000mAh batteries,
one on each port simultaneously at rates up to 4C, or two 6S 5000mAh batteries at rates more than 3C, to have a complete
10S or 12S 5000mAh battery setup charged in as little as 15 minutes or less time! That’s even faster than single port
chargers rated at higher current and wattage output, without the need for cumbersome parallel charging and an even more
powerful power supply, and without giving up the added convenience and flexibility that independent dual port charge,
discharge and cycling functionality offers. And because each port functions independently you can even mix and match
charge, discharge or cycling duties of a LiPo motor power battery and a NiMH transmitter battery, a NiCd receiver battery
and a lead-acid field box battery or just about any other combination you might have.
Additional features include built-in data logging and viewing on the large, class-leading and easy-to-read 48-character blue
backlit LCD screen, internal resistance measurement and an advanced Storage Mode function to automatically charge or
discharge LiPo/ LiIon/LiFe (A123) batteries as needed. Other great features also include dual computer-controlled cooling
fans and temperature protection, an attractive and extremely durable aluminum case, plus the ability to install future
firmware updates available for free download from
www.ThunderPowerRC.com using a standard mini USB cable. Best of
all these incredible features are all available at a value that’s hard to beat while being fully supported and backed by
Thunder Power RC’s industry-leading 2-year warranty. © 2011 Thunder Power RC
Features:
Powerful all-in-one dual port charger, discharger and cycler system with built-in LiPo/LiIon/LiFe (A123) cell
balancers that offer maximum safety, performance and easy-to-see individual cell voltages
The included balance connector adapter boards (2pcs) allow the built-in balancers to be used with 2-8S Thunder
Power-compatible balance connectors as well as the JST-XH balance connectors found on many other brand
batteries from Align, Dynamite®, E-flite®, ParkZone® and more.
Convenient and flexible dual (two) port design charges, discharges and cycles 1-8S LiPo/LiIon/LiFe (A123), 1-24
cell NiCd/NiMH and 6-30V Pb (lead-acid) batteries on each port independently or simultaneously
More than double the charging power, up to 800 watts total (400 watts per port), of other similar class chargers
with selectable charge rates from 0.2 amps up to 20 amps for each port
The perfect choice for safe and ultra-fast charging at rates of 3-6C and beyond for the latest-generation LiPo
batteries
Charge two 5S or 6S 5000mAh batteries at rates up to 4C for 10S or 12S battery setup charge times of as little as
15 minutes or less* – even faster than single port chargers that require cumbersome parallel charging and a
more powerful power supply
Advanced Storage Mode function for LiPo/LiIon/LiFe (A123) batteries will automatically charge or discharge as
needed to achieve storage level voltage
24 user-programmable memories plus built-in data logging and viewing with internal resistance measurement,
battery voltage, input voltage, temperature and more
Fully-adjustable charge capacity limit, per cell end voltage and low voltage cutoff settings for all chemistries to
maximize safety, charge and discharge performance
Durable and compact aluminum case with dual computer-controlled cooling fans and a large, class-leading and
easy-to-read 48-character blue backlit LCD screen
Wide input voltage range from 10.5-28.0V for higher efficiency and power output when using 24.0-28.0V power
supplies
Adjustable output power distribution per port, input power current limiting and low voltage cutoff settings to
maximize performance while also protecting the charger and input power supply
Future firmware updates can be downloaded for free from
www.ThunderPowerRC.com when new features,
battery chemistry and other updates are made available and are easily uploaded to the charger using a standard
mini USB cable
Full industry-leading 2-year warranty and support from Thunder Power RC
*With 24.0-28.0V input and depending on state of charge before charging begins © 2011 Thunder Power RC
Images and Captions
Adaptable Balancing
The built-in LiPo/LiIon/LiFe (A123) cell balancers and included balance connector adapter boards are readily compatible
with all 2-8S Thunder Power balance connectors and the JST-XH balance connectors found on many other batteries.
Capable Connections
Separate main power and balancer connectors allow for simultaneous charging and balancing at charge rates up to 20 amps
on each port while the programming connector can be used with a standard mini USB cable to install firmware updates.
Maximized Protection
The dual ports function completely independently, and with adjustable output power distribution, input power current
limiting and low voltage cutoff you can maximize performance of each while also protecting the charger and power supply.
Specifications:
Type: Dual Port Multi-Chemistry DC Charger/Discharger/Cycler with Integrated Balancers
Battery Cell Counts/Types (Per Port): 1-8S LiPo/LiIon/LiFe (A123), 1-24 cell NiCd/NiMH and 6-30V Pb (lead-acid)
Balancer (Per Port): Integrated for 2-8S LiPo/LiIon/LiFe (A123) with balance connector adapter board for Thunder Power
and JST-XH connectors
Input Power: 10.5-28.0V DC (40 amps max)
Charge Power: 800 watts max (400 watts max per port) w/24.0-28.0V input (see manual for additional information
regarding input and output power)
Charge Current (Per Port): 0.2 to 20 amps in 0.01 amp increments
Charge Voltage: 50% storage and adjustable end voltage for LiPo/LiIon/LiFe (A123), adjustable delta peak sensitivity and
end voltage for NiCd/NiMH and end voltage for Pb (Lead Acid)
Discharge Power: 100 watts max (50 watts max per port)
Discharge Current (Per Port): 0.2 to 10 amps in 0.01 amp increments
Discharge Voltage: Adjustable low voltage cutoff for LiPo/LiIon/LiFe (A123), NiCd/NiMH and Pb (lead-acid)
Cycles: 1 to 15 times with data stored for all cycles
Memories: 24 user-programmable
Firmware: User-updatable using USB
