RCU Forums - View Single Post - Conversion of CG Piper Cub to Tri Gear???
Old 01-23-2011 | 12:09 PM
Zor
Banned
Default RE: Conversion of CG Piper Cub to Tri Gear???
Paul M,
1.5 lbs on nose wheele with 3.25 on each main gear sound good with a total weight of about 8 lbs.
You know of course that you may have to reinforce the fuselage structure where you are moving the main gears.
No doubt you also know that the CG should remain close to where it was with the tail dragger configuration.
Have fun.
Zor
