RE: Cellpro Power lab 8 for pattern use
How will the Cellpro charger handle parallel charging of two (or 3-6) packs that initially hold different voltages?
(I.e. if one pack is half full, and the other pack is almost empty.)
When these packs are parallel connected to the charger, what voltage will the charger see through the balancing taps?
Also, will all the power initially be fed into the lower voltage battery until this "catches up" with the other pack?
Magne
