RE: Evolution 61 Stalls going Vertical
A couple of questions. Did you richen the low speed needle valve yet? What throttle setting does it die out, 1/2 or full throttle? Did you replace the fuel line from the remote nv to the carb? It may be a good idea to pull off the carb and change the o ring.
