RCU Forums - View Single Post - Super Pacer Build Thread - Sorta
Old 01-24-2011 | 06:08 PM
iforbes
Default RE: Super Pacer Build Thread - Sorta
Hi Doug...I know this thread is a bit old, but I am starting to build this same kit. Can you clarify why you decided to put the fuel lines out the side of the fuse?
Thanks!
ORIGINAL: Doug Brindle
Ok Guys,
Wing is framed, pretty much complete, less final sanding. I still need to install the wingtips.
Fuse is pretty much done too. Note the two holes in the right side, those are for the fuel lines.
Tail surfaces are complete.
Canopy is cut and fit.
Fuel tank is built, and partially installed.
I really like the servo installation in the tail. I counter-sunk them into the fuse sides. Nice and clean install.
She's ready for servo installation. Then covering, then final assembly.
I'm building this for a Senior Pattern contest coming up this summer. If ANYBODY has some old (pre-1976) magazines, and could search thru a couple and find an advertisement for this airplane, do a high-quality scan of the advertisement AND the magazine cover, and email to me, I would really appreciate it.
Here's some photos....
