RCU Forums - View Single Post - Evolution 61 Stalls going Vertical
Old 01-24-2011 | 06:32 PM
cahusker
My Feedback: (50)
Default RE: Evolution 61 Stalls going Vertical
ORIGINAL: motoman326
I have an Evolution 61. It has been in a Goldberg Chipmunk for the last 2 years and it ran great. This last fall the engine suddenly won't run while the plane is inclined and stalls out at vertical. It had never done this before. I have replaced all the fuel tubing as well as the fuel tank. I have bypassed the fuel dot. I am planning on changing out the needle valve and or the carb next.
Any other suggestions???
John
John, try this trick that many use when setting the high speed needle. With the engine at WOT (wide open throttle) hold the airplane with the nose straight up. If the engine sags then you are likely too lean and need to richen the needle a click or two, then try the same thing again. If it sags or quits again richen the needle more yet. If you can't get the engine to hold a WOT setting while holding the airplane straight up even after this, then you can proceed to look for other issues. Also has the glow plug been replaced recently? Let us know what you find.
