RCU Forums - View Single Post - Solartex
Thread: Solartex
Old 01-24-2011 | 06:52 PM
DavidAgar's Avatar
DavidAgar
My Feedback: (108)
Default RE: Solartex
I have covered the plane in the primary color and then painted the trim colors with latex paint using an air brush. You will then need to clear coat the entire plane to seal the weave as well as protect it from the gas. You do need to make sure that you have done all your shrinking prior to painting as applying the heat gun after painting does not make for a pretty picture. Good Luck, Dave
