RE: Avonds Rafale
I have a rafale with a P60 in it, flys very well but hi alpha you may struggle, if you won't lots of power for low weight then the best bet is a merlin 90. If you are using the avonds bifucated tailpipe you can also expect a 1-2lb loss in thrust (avonds told me this ) so the merlin with 20 lbs thrust should be perfect.
