ORIGINAL: smokinbarracuda
ok i've now done the transmitter mod like yours yhr using your pictures for help. It works great but still getting the double recoil as expected so i'm going to install a 20 ohm resistor, could you explain where in the circuit it should go? Many thanks for your help
You are trying to slow down the recoil action. So it need to between the motor and the main power supply. I use big sand resistors. THey can take the current.
