RE: New Krill Spark Evo I- Build Thread.....
Andres
Thank you for the speedy response. Although I have not seen a Spark before the quality of this plane seems quite impressive
To be clear you are mounting directly to the nose of the plane with 4mm bolts? Are you placing the 2mm carbon plate between the motor and the spinner ring inside the plane?
