RCU Forums - View Single Post - New Krill Spark Evo I- Build Thread.....
Old 01-26-2011 | 03:17 PM
  #76
lyka's Avatar
lyka
Default RE: New Krill Spark Evo I- Build Thread.....
ORIGINAL: jon bruml
Andres
Thank you for the speedy response. Although I have not seen a Spark before the quality of this plane seems quite impressive
To be clear you are mounting directly to the nose of the plane with 4mm bolts? Are you placing the 2mm carbon plate between the motor and the spinner ring inside the plane?
Hi Jon....
Exactly.
When I start working at this point I could indicate how many millimeters is the plate .... the moment the idea is that we have discussed.
You can get more info in
http://www.rcuniverse.com/forum/m_94..._3/key_/tm.htm
greetings
