RE: Rear diff slip? Doesn't go straight on power
First, make sure that everything spins smoothly and operates smoothly by itself, but you most likely will need to put a thicker silicone oil in the diff. I've found that Traxxas has the cheapest out there, try 30k and see how you like that and if it still pulls, then try 50k.
