RE: *RX60 (92664) Will Not Bind*
Zippi - In my RC club, we use Goop to attach servos to Foam surfaces, or any surface where it is not practical to use servo mounts or screws. Goop creates enough friction with the servo case and the surface you are mounting the servo to, yet, it can be peeled off if you need to remove and reinstall it or mount it somewhere else. Goop does not damage the surfaces it is attached to.
