RE: E-Flight Blade 400 problem
Did the blades (main or tail) touch the ground. Remove one and using an an hex driver, turn the bolt. If not turning straight, you might have bent a feathering shaft (try both font and back). Next will be the main shaft, but if it was only a hard landing and the blades didn't touch the ground, it might not be the case. Check that the tail shaft is straight. I agree with checking the servo operation and the arms that connect them to the swashplate are not bent.
