RCU Forums - View Single Post - Data Loggers - E Pattern
Old 02-01-2011 | 08:02 PM
patternflyer1's Avatar
patternflyer1
Default RE: Data Loggers - E Pattern
Bummer that they are out of business. Hadn't heard that.
I have the Medusa setup. I like it a lot! Don't use it that much though. No need really once you have your plane setup IMO. But good for watching temps/amps while setting up a new plane or motor. I don't really feel the need to check my amps every flight. So while the power panel may be good for some, I wouldn't use it most likely except during the initial flights. Which it would be quite handy for though. That is a good feature! I believe with the Medusa you can put the meter in the plane and it will record max stuff though for the flight. I never tried that though so I could be wrong. Its a cool setup, but I'm sure the Eagle is great also.
Chris
