RCU Forums - View Single Post - E-Flight Blade 400 problem
Old 02-01-2011 | 08:31 PM
Matt90
Default RE: E-Flight Blade 400 problem
I checked the servo connectors there is one that is slightly bent you canonlyjust notice it. The bladesdid nottouch the ground,I have replaced the main shaft because the other onewas bent. How do I check the tail shaft is straight.
Cheers Matt
